跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
After opening an application the CPU and ODD Fan starts running
Hallo
My iMac fans starts running after i opened an application not immediately i bootet up the iMac.
Only the CPU Fan and the ODD fan.
When i run the ASD i get this ERROR several times:
ERROR--13009 SMC error TM_Temp_below_min, the temperature read from the sensor is too frequently below some minimum threshold.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Has the hard drive been changed?
完成的
No I didn`t change the Hard Drive.
完成的
What is the repair history on this machine?
完成的
添加一条评论
1个答案
I would reset the SMC, unplug the iMac hold the power button for 10-20 seconds (unplugged) then Start the iMac as usual. https://support.apple.com/en-us/HT201295
这个答案有帮助吗?
得分 0
1条评论:
Thank you for your response,
i did the reset several times,
now i think the smc controller is broken .
Repair history: i wanted to install an additional ssd.
完成的
添加一条评论
添加你的答案
Philipp 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 66
