跳转到主内容
加入维修社区 - 创建账户
各种电池的维修指南和文档。
Replacement battery doesn't last as long as original
After my original battery started draining faster than normal, I ordered a replacement from iFixit. Replacement was smooth, but the new battery discharges faster than the original battery. Any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
This question was migrated from http://www.ifixit.com/Answers.
完成的
This question was migrated from http://meta.ifixit.com/Answers.
完成的
添加一条评论
3个答案
已选择的解决方案
@fkmattern, floyd, Not positive, perhaps after a few charge/discharge cycles the battery may perform better. When you say battery draining faster than normal you must remember to consider all the Apps,etc. that may be running or running in the back ground. Have all your information ready, and contact Ifixit parts with your concern if you feel the battery is not functioning satisfactorily. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://help.ifixit.com/category/133-cont...
这个答案有帮助吗?
得分 2
添加一条评论
Hey Floyd: if you still have he original battery, look at the rating in Whr and mAh. Then look at the same info on your new battery. If your new battery has a lower rating, that is your reason for the faster drainage rate. A lot of places sell lower mAh batteries to be able to sell at lower cost. Phone batteries do the same thing. I hope this helps. Ken
这个答案有帮助吗?
得分 2
1条评论:
iFixit sells batteries at their rated capacity. Never less.
完成的
添加一条评论
Back up. Your original battery started draining faster than normal. The replacement drains faster than normal. Doesn't sound like a problem with the replacement battery but a short allowing both batteries to drain faster.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
floyd mattern 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 2,130
