跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 个问题 查看全部
Why Does my display go dark after 15-30 minutes?
When powering the iMac on after being turned off for awhile the computer boots normally but after 15 to 30 minutes the display goes dark and does not recover unless the iMac is unplugged for a while or if I put the iMac into sleep for a few seconds then wake it up the display recovers and quickly clicks off.
If I unplug the iMac and power it back immediately on the display will shut of as the computer boots.
When I hold a flashlight up to the display you are able to make out whats on the screen and do things as normal I tried moving mouse around as well as playing audio through the speakers.
I believe this is a problem with the inverter are there any other suspects?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Change out the inverter:
iMac Intel 20" EMC 2105 and 2118 Inverter Replacement
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ethan Stiles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 65
