跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
176 个问题 查看全部
Run iMac on DC power, run power supply without control cables?
Hey,
can anybody tell me if I can run an imac 2017 (power supply maybe similar to 2014) if the power supply just delivers power and has not connected the other control cables. Anybody happens to have one open and can try to power on with just in and out of the power supply connected?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
As this system is so new I doubt anyone even has access to the schematics yet.
But lets look at this from a different direction... I assume you have an RV or boat that you want to use your system in. So getting real AC power is not easy to find or get.
Sadly, you're between a rock and hard place here as desktop systems are designed for AC power use only. While some have tried altering the power supplies in older models they often hit the problem of needing their systems fixed and no-one will service an altered system like this. Besides, you won't get any warranty repairs as you have effectively voided it.
I should point out your system is not a true DC device! It still depends on the clocking of the AC line to work properly. A laptop on the other hand IS a true DC device!
So what to do?? You may want to get an older 2011 system to play around with as its easier to open and you can find full documentation for it (repair & schematics). If you can get it to work then you have a chance to get your newer system to work. Frankly, I think this is going to far but if you must then thats what I would do.
The better approach is to put the time and money into getting a good DC to AC converter. Leave the system intact and use it this way if you want a desktop system.
Or, look at getting a laptop and get an external display if you want something bigger to view. It will likely need a DC to AC converter but you might find a display that runs directly off of DC as well.
这个答案有帮助吗?
得分 1
3条评论:
This is the unit we have used in the field when we didn't have power at a job site and couldn't use a gas generator: Power Bright PW3500-12 Power Inverter the only problem is it chews batteries! Or we used a gas generator: Powerhorse Portable Inverter Generator. In our case it was for a D plotter and/or other devices which were needed. We use laptops in the field.
完成的
Thinking about this in an RV or boat, you might want to get one that uses a VESA mount.
完成的
@mayer Good point! Likely need a few bungee cords to tie it down as well when on the move.
完成的
添加一条评论
Warranty is not my main issue. Inverters are too big and bulky and waste too much batteries, not an option. Laptop is too weak, not an option either. But thanks. I did it with my 2012 macmini and it worked. So what do you mean by AC clocking?
I just need it protable, anywhere.
Has anyone tried by now?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 678
