跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
iPhone 5c HDD Swap
Ok, long story short, I have 2 iPhone 5cs. One is mine, the battery is shot, wont hold a charge for more than 1 hour at idle. The other has had its screen smashed so bad it wont turn on. Smashed screen phone is 8gb with a good battery, dead battery phone has a screen with a tiny chip, bu 16gb of storage. I want the best of both worlds, but getting the battery out im starting to think is impossible, does anyone want to talk me through swapping the hdd or whatever the iphone uses for storage?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
How about following the IFIXIT guide here: iPhone 5c Battery Replacement and all you'll need is the new set of adhesive strips: iPhone 5s/5c/SE Battery Adhesive Strips.
Swapping out the battery is a lot easier than trying to swap out the logic board! All you need to do is find the pulls and the battery just falls out! Here's a vid that shows how you release the strips: How to use Command™ Picture Hanging Strips jump to time-point 1:00 where the wall part is removed. It's the same here.
Replace the adhesive film that secures the battery to the rear case compatible with the iPhone 5s, iPhone 5c, and 1st generation iPhone SE model smartphone. Part #923-0575.图片
产品
iPhone 5s/5c/SE (1st Gen) Battery Adhesive Strips
$3.99
这个答案有帮助吗?
得分 2
5条评论:
ok, so i tried this, but i tore all 4 pull tabs. I dont own an iOpener, and I have no idea to what extent you have to use a heat gun to get the battery out
完成的
@pjsmith727 - If you had that hard a time with the battery I'm not sure the logic board will live though your efforts ;-}
I think its time you found someone local to you who can replace the battery. While you'll need to pay them in the long haul you'll get a working phone out of it.
Remember we all can't be brain surgeons, sometimes our abilities limit us on what we can do.
完成的
Buddy, there's no need to be condescending, I snapped the adhesive strips, that's it, so either tell me how to get the battery off the adhesive strips with a heat gun, or go find someone else to talk down to
完成的
Sorry if you took it the wrong way.
As you encountered issues with both phones batteries glue strips I assumed you were a bit heavy handed. We see many different skilled folks here. It's not easy to know the skill set or if someone is reaching to high.
Why don't you contact @jessabethany to see if she can bail you out here. She knows her stuff! I'm sure she can take both phones and make a good one out it for you. She may even be able to get you two working phones!
完成的
@pjsmith727 I don’t think he meant to be condescending, in my experience @danj has always been nice and helpful.
完成的
添加一条评论
iPhones and other smartphones do not use removable storage like PCs do. They use chips that are soldered to the logic board and are unable to be replaced. You could try swapping the logic boards but that almost certainly wouldn't work. Good luck!
这个答案有帮助吗?
得分 1
2条评论:
so how difficult is swapping the logic board? I'm not incompetent here, I did the screen replacement myself
完成的
Here's the IFIXIT guide: iPhone 5c Logic Board Replacement
完成的
添加一条评论
iPhones are lego projects. There is no reason why you can't simply follow the iFixit guides already here to tear down both phones and build one good one. Yes a 5c will work with board A, battery B, screen A, housing B, etc. all are just legos.
Re: getting a battery out, use a plastic tool and pry a bit from the edge of the housing not the logic board until you can get some tweezers under there and grab the white battery strip and pull it again. Be careful of metal tools puncturing the battery, although it is fun to watch the explosion.
Ah--just noticed this is a 5c not a 5s. While the 5c may have a bad battery, it is more likely that the 5c also has a bad tristar chip on the logic board. 5c owners tend to use cheap gas station charging cables which do not protect the phone from charger voltage surges which damages the tristar chip on the logic board. Repairable, but you'll either need to take up microsoldering or send it to someone who has the equipment to do board repair on iPhone boards.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
PJ Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 354
