跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
Is it possible to repair my USB port?
One of the USB ports (closest one to the user if using the laptop) does not function. Plugging any type of device, (monitor, flash drive, external hard drive, etc.) does not show up in any form on the laptop.
Is there a way to check the connection and or repair it without replacing the logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
It's according to what has happened to it. As you can see in step 33 of the logic board replacement, it's soldered onto the logic board. If one of those joints has broken loose, it could be soldered back on by an experienced tech willing to do it. MacBook Unibody Model A1278 Logic Board Replacement
这个答案有帮助吗?
得分 4
1条评论:
Or... you can just do it yourself, not that difficult actually to do. Just like soldering on any other connector to a board
完成的
添加一条评论
This helped fix my usb http://howtofixstuff.blogspot.com/2012/0...
这个答案有帮助吗?
得分 0
1条评论:
Don't follow that link posted by Misternoname5, that takes you to a repair option for PC users. He could have summed it up by saying "UNINSTALL" your driver for USB then "REINSTALL".
I am in the same boat with a loose USB port. I will attempt the solder technique a report back.
完成的
添加一条评论
http://macs.about.com/od/usingyourmac/qt...
my middle usb port sometimes doesnt see anything plugged in but will show power on a flash drive. i reset the smc and that always fixes it. hope it fixes yours
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan Barry 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 10,460
