跳转到主内容
加入维修社区 - 创建账户
Asus ZenPad S8 是 Asus 推出的一款 8 英寸 Android 平板电脑。于 2015 年 6 月发布。型号:Z580CA。
Replaced broken screen but touchscreen doesn't work
Hello,
I've recently replaced the screen of a Asus Zenpad Z580CA. Haven't glued the screen on yet, just connected all the cables and booted it to see if it works. No issues with the screen itself, everything looks fine. But I have no response to touch. Anywhere i press there is no response, it's not a few dead zones, the whole screen isn't working. Should I replace the screen again or could it be that something is badly connected? And if so what cables/circuitboards manage the touchscreen?
Thanks in advance for the help!
Update (07/16/2017)
I have no idea what else I can try...
Help would be greatly appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
change your screan and try again
这个答案有帮助吗?
得分 0
添加一条评论
did you insert the touch screen flexible correctly?
这个答案有帮助吗?
得分 0
4条评论:
I assume so.
Which ribboncable is the one that connects the touchscreen?
由完成的
i 'm not sure about the position of the cable itself usually every cable must be fit to the socket just make sure it is well positioned and locked
由完成的
Refitted all cables a few times now, cleaned all contacts as well. Both no luck
由完成的
are you sure the touchscreen is not broken? try another touch screen module hope work
由完成的
添加一条评论
添加你的答案
Ziyedm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 612
