跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
Is my MacBook Pro 15" mid 2009 dead?
My poor MacBook Pro 15" mid 2009 is about 8 years old now and for the past year I haven't been using it that much.
I tried to turn it on a few days ago and it was stuck on the boot-up bar for at least 45 minutes then it went to the file folder icon with the question mark.
I asked my friend and he suggested formatting the hard drive as I didn't have anything on it I needed to keep. So I bought the tools and hard drive enclosure and carefully took the hard drive out and put it in the enclosure and hooked it up to my desktop PC.
I got it formatted and made it an exFAT drive and it showed healthy and the full space available. I thought okay great this should work...well not quite! I reinstalled the hard drive back into the my MacBook Pro and it either has a plain grey screen with nothing showing or the file folder with the blinking question mark.
I tried command+r while powering up, I also tried command+s while powering up. I tried leaving it alone...nothing is working!
I know it's an old computer now and it had a good life but any suggestions what else I could try?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
So what happened is you connected it to a PC and quick formatted to "exFat". This is a Windows format, and cannot be used by OS X.
You need to find someone else with a Mac, and get a USB thumb drive.
Download the latest OS X and create a Bootable USB Installer.
Once you do this, you need to start the installer, and use its Disk Utility to format the drive as Mac GUID partition map & Mac OS Extended (Journaled) partition.
Once its formatted, exit Disk Utility, and install the OSX.
I have to mention though, the symptoms you mentioned sound like your hard drive is failing, so you should get a new one and follow the same instructions.
这个答案有帮助吗?
得分 2
1条评论:
@avanteguarde thank you
完成的
添加一条评论
Hello,
You should check for the SATA Cable that runs between the HDD and then plugs in to the Main logic-board. It's a common and well known problem.
You should be able to find the SATA Cable online. Buy a new one and not a used one. Had the same issue with 2 customers in the same Week.
Greetings a Swiss Technician
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Carrie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 388
