跳转到主内容
加入维修社区 - 创建账户
A1103 型号 / 1.25、1.33、1.42 或 1.5 GHz G4 处理器
mac mini wont START UP
i turn on my mac mini
i hear the start up noise
and all i get is a blue screen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Can you start it in Safe Mode?
To start up into Safe Mode (to Safe Boot), do this:
  1. Be sure the computer is shut down.
  2. Press the power button.
  3. Immediately after you hear the startup tone, hold the Shift key. The Shift key should be held as soon as possible after the startup tone but not before.
  4. Release the Shift key when you see the gray Apple icon and the progress indicator (looks like a spinning gear).
  • During startup in Mac OS X v10.4 or later, you will see "Safe Boot" on the login window, which appears even if you normally log in automatically.
  • During startup in Mac OS X v10.2 through v10.3.9, you will see "Safe Boot" on the Mac OS X startup screen.
To leave Safe Mode in any version of Mac OS X, restart the computer normally, without holding any keys during startup.
Info sourced from Apple support forum
You can also be more proactive:
  1. Try your install CD that came with your Mac, reboot, hold down the letter C after you hear the chime, and when it boots to the installer, pick a language, and then run Disk Utility by finding it in the top menu.
  2. Instead of holding down C at startup, hold down the letter D and make sure all your hardware's okay.
这个答案有帮助吗?
得分 2
1条评论:
+ complete answer, very good
由完成的
添加一条评论
You should update it and restart
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ilias tsepas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 22
总计 6,291
