跳转到主内容
加入维修社区 - 创建账户
Saitek X52 Pro HOTAS(手不离杆)游戏控制器的维修指南。该控制器由 Saitek 公司发布。
Buttons Don't Work on stick
When I pull the joystick to the left the buttons work just fine. But if i pull my joystick to the right the buttons on the stick stop working any idea?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Do the buttons on the base still work, independent of the joystick position?
Do the LEDs still light up even when the buttons stop working?
If both answers are "yes", it's probably a worn PWM signal cable between the joystick and the baseplate. I'd suggest replacing it with some slightly tougher wire. I've made a guide a while back on imgur, I'm afraid. But it should point you in the right direction. It assumes you know how to solder, though.
这个答案有帮助吗?
得分 1
添加一条评论
Long time since last response nut i went thru cables on my joystick and all seem to work and conections checked with multimeter. so any advice?
这个答案有帮助吗?
得分 0
1条评论:
Mine seemed fine with a multimeter when disassembled, but probably had some damage around the hinge. It fixed itself when I replaced the cable.
由完成的
添加一条评论
添加你的答案
b00053195 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 2,192
