跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2265 个问题 查看全部
Can't open iPhone 7 to save my life please help!
Hey guys,
I recently purchased an iPhone 7 with a cracked screen on eBay just to do one successful test run before I start offering the repair to customers. It just came in the mail yesterday and... I can't even start the repair, because I can't get it open. I have tried the iOpener with iSclacks, which did nothing. I ruined a pair of needlenose tweezers trying to jam them in there and twist it to get an opening, and feel like I almost got somewhere, but I didn't. Then I tried an iSesamo like in this video: https://www.youtube.com/watch?v=hIs6vLdH...
I don't know if I did it incorrectly, but it did not work. If anybody has any tips on how to do any of these correctly, or an alternative method, I am open to anything at this point since I just want to get this phone open. Thanks a lot!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
I did my first a few weeks back and yes the Adhesive is NO JOKE. Need to be patient plenty of heat and some picks. Gotta go slow with heat and get a pick in it. More heat then slide across the bottom then up the left side and just be patient. Good Luck
这个答案有帮助吗?
得分 0
添加一条评论
The adhesive on these is very strong because of waterproofing. Try clipping the screen back in and use the method that is not the iSclack method.
EDIT: Did you remove the pentalobe screws?
这个答案有帮助吗?
得分 0
4条评论:
Yes, I removed pentalobes. But I can't even get it opened a crack.
完成的
Try the first method on this guide. iPhone 7屏幕总成更换
完成的
I did that with no success, maybe I didn't let it heat up long enough.
完成的
Hmm. I've never opened a 7 myself but as Jeff said the adhesive is very strong.
完成的
添加一条评论
At Simple Computer Repair in Monument, Colorado, We have opened a number of iPhone 7's. The adhesive is definitely strong. We use a Kobalt heat gun on the edges. Start at the bottom (left side of the home button. We heat the bottom and left side first. We use a single edge razor blade inserted vertically between the phone case and the screen. We then gently pry up on the screen until it begins to separate. We then run the razor blade along the side releasing the adhesive. We use opening picks to hold the screen open and keep it from re-adhering as we work along the edge. Don't put too much of the razor blade in, especially along the right side so as not to cut the home button cable. Once you get through the adhesive, remember that the iPhone 7 opens like a book, not bottom to top. Good luck.
这个答案有帮助吗?
得分 0
添加一条评论
I would say there is no way to open this phone without damaging the paintwork. If you use metals tools you WILL scratch the surface and possibly chip the fine edge on the glass. All the videos show the phones coming apart really easily, but they are a total con. The adhesive makes it really hard to move, even when warmed up.
I am happy to be contradicted on this, but nobody has filmed a genuine phone being opened for the FIRST time using this method.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Garrison Bates 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 2,798
