跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Device Restarts Whilst Restoring (iPhone 7)
Hi, Thanks in advance.
I am trying to restore an iPhone 7 that is disabled.
I have downloaded the latest iOS update in iTunes, however each time I put the iPhone in recovery mode and proceed to restore via iTunes the iPhone decides to restart about 2 quarters of the way through restoring. The device goes back to the disabled screen and iTunes continues as if nothing happen. Then iTunes comes up with a error message saying the device cannot be found (i.e. it was unplugged).
Any suggestions on what might be causing the device to restart during the restore process.
iTunes is up to date. Mifi Cable and I'm using a Mac.
Please note I cannot access anything on the iPhone as it is in disabled mode.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Make sure the battery is fully charged? Use 3UTools instead (You will need a computer that is running windows to use this).
Try other USB ports?
You might just need to use another computer to restore the iPhone 7 at worst.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your advise, I tried with my MacBook and it worked first time.
完成的
添加一条评论
添加你的答案
Micah Morgan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 6,708
