跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Headphone jack cable replacement
Where can I get info on how to reattach the button holders for the flex cable? There is not one guide on the internet and this is frustrating.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have answered this already... please only ask the question one time.
I learned to do this repair only by reading this guide! You need to study something first before jumping in, read the guide/check the phone/check the cable/ work it out in your head. There are no other guides as you don't need them. Have you tried removing the jack? Once you have done the removal then the replacement should be easy.
You may also like to browse the questions for something related..
完成的
添加一条评论
2个答案
已选择的解决方案
iPhone 3G Headphone Jack Replacement
as it says at the bottom of the guide-to replace simply reverse the steps. i have done this repair many times and you need nothing other than the replacement jack. Re read the guide and perhaps it will make more sense- the part you will remove is identical to the one you will replace.
这个答案有帮助吗?
得分 3
2条评论:
As I stated... button holders are already disconnected so how can I reverse the steps when it does not include removing teh button holders? Please read before you post.Can anyone here please provide some info? Perhaps someone with the details on how to do this with the button holders? I would be very appreciative.
完成的
right!
is the part you have this http://cgi.ebay.com/Iphone-3G-Headphone-...
or this?
http://www.ifixit.com/iPhone-Parts/iPhon...
as you can see not quite the same.
we try very hard to answer questions but can only go on the information you give us. saying that the button holders are already disconnected doesn't really make things clear. Disconnected from the phone? from the flex? from the buttons?
完成的
添加一条评论
此回答最初是针对另一个问题
Thnaks for the reply. The button holders are disconnected from teh phone and the cable. I have this part:
iPhone 3G/3GS Headphone Jack Assembly
Perhaps I should purchase the other one.
Now I see what you are talkking about.
Hmmmm. My bad.
Replace a dirty or corroded headphone jack, or a damaged internal audio or power button switch.图片
产品
$14.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Damon Rose 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 3,225
