跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Microphone not working when calling on loud speaker.
Hello,
I recently got the iPhone 5 but for some reason when I am calling and I put the call on loud speaker the person on the other end can't hear me but I can hear them. Note that this only happens when calling on loud speaker, "regular" calling works just fine.
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hopefully you just have to replace the flat cable including front camera and proximity sensor. It's a pretty easy and inexpensive replacement and in any case the first to try to resolve your issue.
这个答案有帮助吗?
得分 2
添加一条评论
Does your mic work when you talk to Siri?
In my opinion, it sounds like the charge port flex needs to be replaced since that has the mic that works in speaker mode. On the newer phones you have 3 separate mics, 1 for siri, one for when your have it on speaker mode and the other for when you're just using your ear speaker. On the 5, I can't remember if Siri uses the same as the one for the speaker. But regardless I think you need that flex replaced.
Let me know what was the fix, if you get it fixed. I'm curious to know. Hope it all goes well!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Leon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 64
