跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone 7 freezing after screen repair
Hi, i work at a phone repair shop and i constantly have iPhone 7s that come back with a problem where they will be using the device and randomly the screen will freeze and they will have to shut it off and turn it back on. It only starts happing after the repair. was curious if this is a known problem and if it could be a repair oversight or faulty parts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
7个答案
最有帮助的答案
I have brought this to the attention of many parts suppliers and this link will give you everything you need to know. This is why apple has a calibration machine, The iPhone 7 through 8 plus will experience this due to 4 separate manufactures of screens, LG, Toshiba, Sharp, and JDI. If your screen does not match that it will need to be calibrated with the machine or it will not communicate properly. Best solution is to check the first 3 characters on the screen and try and find one that matches the original.
'''https://webuylcds.co.uk/2018/05/15/to...
这个答案有帮助吗?
得分 3
1条评论:
Or use eprom reprogrammer for 50$
完成的
添加一条评论
Restart your iPhone 7(press and hold power button and volume down untill you see the Apple logo),if this still not work, backup your iPhone and do a factory reset.
这个答案有帮助吗?
得分 1
1条评论:
It worked. Thank you.
完成的
添加一条评论
Sounds like a screen quality issue. Have you tried different screens?
这个答案有帮助吗?
得分 0
添加一条评论
i also work at repair shop and having same issue , dont know what is it yet ................
annoying thing is customer are having problems because of my service :(
这个答案有帮助吗?
得分 0
添加一条评论
If each time it's the same thing, it's due to bad quality LCD. Buy a new lot of LCD.
这个答案有帮助吗?
得分 0
添加一条评论
My screen is on, but it doesn't respond when you tap, slide, or try other gestures. Wont even let me slide the power button off nor let me enter my passcode. Could i just need a whole new screen?
这个答案有帮助吗?
得分 0
1条评论:
You need new screen
完成的
添加一条评论
Please don’t read comments from others… EPROM reprogramming needed. This is the only real and working solution. Costs 50$
https://www.youtube.com/watch?v=Uv4BDpWf...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Arima 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 3,806
