跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
It will turn on but only charge to 50%
My samsung galaxy S6 got rained on, and since then it will turn on and screen looks normal and functions normally, but it will only charge to 50%, but when I unplug it then it dies. Do I need to replace the charging daughter board? If I do, then will the home button finger ID still work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Both front and back are cracked, between replacing the battery and both front and back glass. Is it cheaper to replace phone?
完成的
Unless you know how to do a glass only repair, it is usually not worth fixing. If the LCD is black, I would just get a replacement then.
完成的
添加一条评论
2个答案
已选择的解决方案
Sounds like your battery is failing to due liquid. Any time you get liquid on a battery, you want to go with a new one. I would first try a new battery before replacing the daughterboard. If battery fails, then try the board. That should solve any issues you are having with this device.
更换三星盖乐世S6的电池
更换三星盖乐世S6的子板
Samsung Galaxy S6 电池图片
指南
更换三星盖乐世S6的电池
难度:
困难
40 minutes - 1 hour
Samsung Galaxy S6 子板图片
指南
更换三星盖乐世S6的子板
难度:
困难
45 minutes - 2 hours
这个答案有帮助吗?
得分 0
添加一条评论
Both front and back glass is cracked, and bad battery, with all of these repairs, would it be cheaper to replace the phone?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amy ford 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 17
总计 148
