跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
433 个问题 查看全部
Cant find an answer I found before?!
looking through your database I found a detail guide to the use of Disk Utility on how to format the new HDD i'm about to install but i cant seam to find it any more can some one point me to it pls.
Also will putting an larger HD than I took out of the imac be a prob. i.e. will the sys bios see it with out in put from me? thanks for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks for your help I also found the art. I was looking for bookmarked it this time lol just got a email from you guys that my drive is on its way I'll post up the out come after I install it and i am up and running.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Bryan,
1. Boot from Install DVD
2. Choose Language -> and wait
3. Click on top Menü -> Utilities
4. Click on Disk Utility
5. Choose new HDD on left side with the GB in it
6. Choose on the right the erase pane
7. Choose "Mac OS Extended (Journaled)"
8. Click Erase.
The new Disk is now formated and ready to use.
You don't need to partition the HDD if no partition is created yet. Erase is absolutly fine.
这个答案有帮助吗?
得分 2
1条评论:
Set it to one partition
完成的
添加一条评论
添加你的答案
Bryan Seneviratne 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 539
