跳转到主内容
宏碁所制造的台式机的维修和支持指南。
70 个问题 查看全部
opening the am3400 case
I want to open the case of my AM3400-U2052 without a crowbar. So I can have a look around. My sound is sporadic and I suspect a poorly wired socket for the speaker plug or a poorly seated card. But first I have to look under the hood and the case refuses to come off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Tom Franczak, Normally there will be a couple screws to remove from the back that hold side cover, then slide the cover back a 1/4" to unlock from frame tangs and lift cover off. The link below is to a service guide(not your exact model) but will show side cover removal/instruction. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/232867...
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Tom Franczak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 137
