跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
Strange problem with the microphone
The problem occurred about a week ago. When making calls I can't talk or hear. I read that a lot of people could just use speaker and everything would be fine but my speaker icon stays gray and the iPhone doesn't let me use it. I tried testing the microphone in Voice Memos ,but just like the speaker icon, it was grey and didn't let me use it.
I don't know does this matter but my headphone jack stopped working just when the mic did.
P.S. It probably happened when I brought my phone with me on the tennis court and a wind probably threw sand into the microphone.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
did you try a hard reset of the phone? sometimes is just a bug.
完成的
添加一条评论
3个答案
已选择的解决方案
Voice memos and phone calls use the same microphone, located in the charging dock where the ear plugs jack is located too. Probably your lightning dock is faulty and needs replacement and everything should be fine.
这个答案有帮助吗?
得分 2
添加一条评论
Did you get this fixed? I have a SE with the same problem. I replaced the charge port flex cable and that didn't fix the issue. I also replaced the front camera flex cable which didn't fix the problem.
这个答案有帮助吗?
得分 1
1条评论:
I Have the same problem and i couldn’t know which Microphone having the issue
完成的
添加一条评论
Hello. So, the iPhone has 2 microphones. One inside of the ear speaker grill and the one on the bottom of the phone. The one on the bottom of the phone is the one that is ONLY used for phone calls and Voice memos. FaceTime and talk to text is all in the microphone that's in the ear speaker grill. So if you have no issues during calls, the problem is going to be the microphone in the ear speaker grill.
这个答案有帮助吗?
得分 0
5条评论:
You forgot one microphone, there are 3 ;)
完成的
@arbaman where's the third one? One of mine is nuts
完成的
Nevermind, found it. One is in the earpiece, one with the truetone flash and one besides the lightning connector
完成的
What do each mic control? @w4t3r @arbaman
完成的
@ramonx1322 Generally speaking, the bottom microphone is used for phone calls and voice memos, top front for video calls and video messaging, top back microphone is used for videos recording. I believe developers can change instructions sets for Apps up to a certain extent, but software development isn't my daily bread and I can't be of more help with that.
完成的
添加一条评论
添加你的答案
Ivan Peevski 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 32
总计 2,942
