跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Slow to recognize SIM
Hello
When I insert my SIM card, the status in the upper left corner is slow to update from No SIM to the name of the provider.
Same happens when I remove the SIM card. Then it takes a minute till the status in the upper left corner of the screen is updated to 'No SIM'.
Sometimes it won't update at all, even slowly. Then A reboot will do the trick.
I want to know what causes this and how it can be fixed since I need to resell this phone.
Any help is highly appreciated :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
You might want to do a full restore in DFU mode and see if that solves your issue, but from your description it doesn't sound like an overly disturbing matter. Some phones are faster that others of the same model, but since there's a quite complex operating system behind I've always considered these small glitches acceptable. I'm sure some of the real true experts here around will be able to better enlighten both of us ;)
这个答案有帮助吗?
得分 1
1条评论:
I buy iPhones quite often to resell them. I do a DFU restore on all of them to make sure all software is installed properly etc.
It's annoying, but I'm kind of a perfectionist and want it top notch for the next owner :)
Phone is 3 years old, that might be the cause of it being so slow to update the SIM status.
Thanks for your answer Arbaman
完成的
添加一条评论
添加你的答案
Didier Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 263
