跳转到主内容
加入维修社区 - 创建账户
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
No Display and Repeating Charge Chime
Hello, I have 2 iPhone 4's on Verizon. I wanted to swap the screens on them since one is in locked and the other one is shattered. After a very long process of lost screws and frustration I finally have the good screen on the good phone. The only thing it does now is show up in iTunes and keep making the charge chime. I have put the other board in the housing and it does the same thing. I have even tried the cracked screen on both boards and the same thing happens. I would really appreciate it if you could help me out.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
Sounds like either board damage or both the screens got damaged from improper installation.
完成的
I have the same case, except my screen is shattered. The screen worked like that though, and my phone is a little rough, any fixes anyone?
edit: havent replaced the screen yet, its just like this
完成的
添加一条评论
1个答案
Very unfortunately, Dylan, your 'good screen' is probably bad. Exactly what you observe (no display and repeating chime) indicates a broken or missing screen. You have my sympathy: replacing iPhone 4 front/screen assembly is onerous. Too I broke an otherwise operational screen, by bending its cable.
See Wiki page: iPhone endlessly repeats the "power supply accepted" sound or vibration.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dylan Mclaughlin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 34
总计 761
