跳转到主内容
An audio storage device that uses magnetic tape to record and play back audio input.
29 个问题 查看全部
motor wont run when switched to forward or reverse
I have a teac tape recorder a-2050, when power is on , the vu meters lite up and if I activate one of the two micro-switches the motor runs,but if the long bar switch to allow the tape to play, the motor will not run, in the back I can see the relay pull in and thats the only indication that some thing is alive. I have worked on tv and radios with schematics but have nothing for this.
Duane
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Use a multimeter to test the switch. If you plan on keeping the machine consider buying the repair manual for it. I found this one on eBay: http://cgi.ebay.com/TEAC-A-2010-A-2050-A...
这个答案有帮助吗?
得分 2
添加一条评论
These run on 4 idler wheels under the front panel that drives the capstan motor. They are probably gummy and deteriorated.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
kb9zqu2000 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 13
总计 711
