跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Why won't my home button click?
Hi, I recently replaced my iPhone 5s' LCD. The replacement was a success, but the home button isn't clicking. It just feels like it's loose. Touch ID work fine though.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
In my case the button has shifted. I put it back and it works fine now for me
这个答案有帮助吗?
得分 0
7条评论:
How would i do that? I thought it was because something was loose at the home button.
完成的
You sure you didn't mount the metal plate behind the home button upside down?
The correct orientation is like a chimney facing up.
Also is it like too dipped in? If this is the case I just bend in the metal of the home button metal plate middle after removing it closer to the home button and install it again then test clickyness.
I've had some aftermarket screens with the plastic screen frame going to the home button placement area when it should not as it should rest on glass not plastic for the black rubber gasket.
完成的
The metal plate is behind the home button, but not sure if it's upside down. I will look further into this as soon as i have access to my phone. I will let you know how it goes :)
完成的
The correct orientation is as shown here:
https://d3nevzfk7ii3be.cloudfront.net/ig...
完成的
In my case tearing down the digitizer and putting it back together although it was plain hard.
完成的
显示更多的2条评论
添加一条评论
Try going to the Settings App and select general and then to accessibility. Check for the interaction section and assistive touch.
Now tap the button next to assistivetouch and slide to the position (it should turn green)
这个答案有帮助吗?
得分 0
添加一条评论
iOS has a neat feature that helps when hardware buttons stop working. To activate this, go to the Settings app, and select General, then Accessibility. Scroll down to the Interaction section, and tap AssistiveTouch. Now tap the button next to AssistiveTouch so that it turns green and slides to the on position.
这个答案有帮助吗?
得分 0
添加一条评论
my iphone 8 plus home button was just clicking and now it’s not . it still works , my touch id and everything but it’s not clicking. what do i do ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Esben V 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,963
