跳转到主内容
The Dyson V6 Motorhead Vacuum is a lightweight, cordless vacuum. It easily converts for handheld cleaning using a simple dirt bin instead of replaceable trash bags.
Why is my Dyson not working?
my Dyson inst working and i have no clue why? how much would it cost to be looked at and fixed and who can i take that to?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Please give us a description of its symptoms. What will it do and won't do.
完成的
only a year old-used maybe 10times-suction for 2 times , then I went back to using my $50 Shark-was going to throw it out then saw it was guaranteed for 2 yrs. Purchased 5/14/16 Where can I take it for repair? Most expensive vac I've ever had & never worked well.Tried my neighbor's first & his is old & still works fine. TY
完成的
添加一条评论
4个答案
最有帮助的答案
I would first suspect a bad battery. When you put it on the charger, does the light(s) glow? If you have access to another battery, try it. If that fails, the power button or wires to the battery have broke or failed. Use the below guide to check that out.
Dyson V6 Motorhead Motor Replacement
这个答案有帮助吗?
得分 3
添加一条评论
Just tell me where I can get it repaired? My cheap Shark is almost 3 yrs old & works fine.
这个答案有帮助吗?
得分 0
添加一条评论
email answer to Granniejude@aol.com
这个答案有帮助吗?
得分 0
添加一条评论
My vacuum it works for a short period of time and stop. How can I fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
taylah woollard 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 24
总计 2,922
