跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
My iPhone not turning on (because the update is interrupted)
Im updating my phone Iphone 5s to be exact when the internet suddenly disconnect (No more wifi connection ) my phone suddenly turns off and not turning on what could be the possible deffect ?
I cant restore it on itunes .
Is this already a dead board ?
How can i fix this thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Connect your device to your computer, and then launch iTunes of 3uTools to see what mode your device is in.
If it is in DFU mode or recovery mode, just easy flash your device to enter Normal mode.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I've never seen a case of this before.
The way iDevices work is that it first downloads the software, disconnects from the Internet, then applies the update.
I would first download the iPhone firmware on a computer with iTunes from
http://www.iclarified.com/750/where-to-d...
remember where you downloaded it
Then plug your phone into the computer and put your phone into DFU mode.
There will be a message if done properly that you need to restore your iphone.
On a Mac hold Option on the keyboard, and click Restore. Then choose the firmware you downloaded.
On a PC, hold the SHIFT on the keyboard, and click Restore. Then choose the firmware you downloaded.
If this does not fix your issue, you do have a non related hardware problem. This will require different troubleshooting methods.
这个答案有帮助吗?
得分 2
7条评论:
What should i download the firmware that im installing or my previous firmware ?
完成的
Download the latest one (I think its 10.3.2).
完成的
Okay thanks :)
完成的
Is their any possibility that the board is broken due to the failed updating of the phone ?
完成的
Not from a software update.
完成的
显示更多的2条评论
添加一条评论
You could try entering DFU mode if none of the solutions above work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Fixie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 192
