跳转到主内容
An all-new Passat, based on the Volkswagen Group B5 platform, was launched in 1998 in North America.
42 个问题 查看全部
loosen power and the oil light came on
I have a 02 v6 passat one day driven it .. it started loosen power and the oil light came on ,so I drove it to the mechanic and came back . They said engine was locked up and have to have a new motor, but I can turn motor by hand so I know it's not locked up.. what could it b ?? I've heard of many things read many things anyone who had the problem email me at Jongfella@gmail.com.. thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Jon Jon, If you can now turn the engine over by hand, it does sound like the engine is not locked up. But if the oil pump failed or you ran the engine low of oil and continued driving when oil light came on there could be internal engine damage/wear. Did the first mechanic say whether the engine was low on oil or pump failure or why he felt engine had locked up. If car is not starting and you can not trust what the first mechanic/shop told you, get a 2nd or even 3rd opinion. The shops may have to pull oil pan or use video scope to see/verify what damage's are done and to what extent. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Jon Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 67
