跳转到主内容
My iMac is stuck at the loading screen
I recently obtained an imac g3 (slot loading) from my highschool, as they had no use for it and were going to throw it in the dumpster around the back of rhe school. My friend and i started it up ( at school, as the one condition was we had to wipe the hard drive) and wiped the hard drive. I took it home, plugged it in and turned it on. The happy mac chime sounded and it went to the screen where it shows the apple logo and a loading wheel. I have tried all the ways to fix it ( reset the pram, single user mode commands, verbose mode commands, trying to boot in safe mode and going into the boot options) but to no prevail. I think i will need to buy an os disk and boot it off that but first, is there any other way?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
what method did you use to erase the hard drive? Disk or open firmware?
Also, what OS did you install on the machine? as the earlier models have more OS restrictions to later models, and the ram spec makes a big difference, especially if you are trying to get a later OS on it, such as 10.4.
Can you confirm the exact spec of the machine you're dealing with as well? as there are 4 ranges with the M5521 family number.
完成的
添加一条评论
1个答案
最有帮助的答案
There is usually a plate inside the port door on the side of the machine that will tell you which machine you have. Here are 13 different ones: http://www.everymac.com/ultimate-mac-loo...
Select which one you have to see what the original operating system was and just how high it can go.
The school may still have the original installations disks. If not, you will be able to find them on eBay.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Memphis Hancock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 732
