跳转到主内容
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 个问题 查看全部
Where to locate CMOS battery
I'm trying to replace the CMOS battery in my Asus X555la and am unable to find the battery itself. A simple picture of the battery or a step by step guide to get to it would be great. I've completely dismantled the computer and flipped the motherboard over with no luck.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Hi James, have you found the solution to your problem? Is there CMOS battery on the motherboard?
完成的
The 555L does not have one. It has a capacitor
完成的
添加一条评论
2个答案
已选择的解决方案
If Asus is still using CMOS batteries (most companies now use a capacitor on the logic board), it may be similar to this: Asus X551CA CMOS Battery Replacement
这个答案有帮助吗?
得分 2
1条评论:
Hi i would like to know where is the CMOS battery on the asus X555QG
完成的
添加一条评论
In my Asus laptop, its near on off switch, its not a big deal to replace, on the image, its near Asus logo.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
James dunne 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 25
过去 30 天: 103
总计 21,036
