跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
Internal Power Supply Replacement Issues
Hello,
i think this is going to be a bit hard to explain but i shall try!
so the Xbox i have, it doesn't turn on anymore. found the problem in the power supply. it obviously had some kind of component explode. big burn marks all through the power supply. i had another Xbox one s who's power supply was absolutely fine. turned on and all. out of curiosity i grabbed that one and put it in the Xbox that had the burnt out power supply. that didn't work. didn't turn on so figured the MB is stuffed. the weird thing is, when i put the power supply back in to the console i know works, that now no longer works!
anyone else experienced this? or has anyone successfully fixed this issue?
Also, before anyone mentions it, warranty or contacting MS is most certainly not a option.
thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
yes it seems that the MB has a short and has killed the PSU
完成的
添加一条评论
1个答案
最有帮助的答案
@tronicsfix meanders in here lots. This is his specialty.
He even does it for a living so this will poke him.
https://tronicsfix.com/index.html
这个答案有帮助吗?
得分 3
4条评论:
ahh yes, i know steve! the man. watched many of his videos on youtube :)
完成的
I wish @tronicsfix was more active here, I need him too. He only signs on every few days.
完成的
Hmmm...I haven't seen this type of thing before in the Xbox One S. Sounds like there's something on the motherboard that's causing and issue with power supply's...although you'll want to be sure that the power supply is plugged fully into the motherboard on the good console...sometimes they are hard to get fully seated.
I'm assuming you've taked a good look at the motherboard that's burning out power supply's?
Good luck...sorry I can't help more.
完成的
no worries steve :) i appreciate the help. i thought this was an unusual issue. it seems the motherboard is killing working power supplies right away.
完成的
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 2,397
