跳转到主内容
黑莓手机的维修和拆解指南。
448 个问题 查看全部
Why won't my blackberry curve charge even with a new battery?
I just got a new blackberry curve. For some reason it won't charge. It does not have water damage. I went to the phone company and they said I need a new battery. I got a new one and it still won't work.I tried the new battery because the warranty is up and do not wish to get a new one because of the minimum fees that apply when buying it. Could you please give me advise to resolve this issue without getting a new phone? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My man has a blackberry curve a 9320 and the charger is not working on I put my Itableton it its work's
完成的
添加一条评论
2个答案
已选择的解决方案
Have you tried a wall charger and USB charger? Does the charge icon come on? Check the phone port take a look at the 5 gold pins where u insert the charger and make sure they are not bend and align right. Also clean out the port to make sure there is no debris in there, if this does not help, try pulling the battery for 10 seconds if it still doesn't work, you may want to try another cable if none above works you most likely have a dead port and a replacement is in order. Hope this helps a little bit.....Good luck
这个答案有帮助吗?
得分 0
2条评论:
what is a dead port?
完成的
this question is over two years old:-) You may need to elaborate on your question. what port and how do you know its dead? Do you mean the charging port?
完成的
添加一条评论
Help me man needs it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sara 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 8,650
