跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for Kenmore Microwaves.
How do I replace door
How to replace door on kenmore microwave
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hey Richard! What exact model of Kenmore Microwave do you have? Is the whole door broken, are the hinges sticking, or is it just not locking into place? Give us some more detail so we can help. There are plenty of Kenmore parts and door repair videos out there, so we should be able to find something to help. Thanks.
完成的
添加一条评论
1个答案
已选择的解决方案
Unplug the microwave and set it on a table or workbench. If you have a built-in microwave, you may have to remove
some mounting screws or retention clips to get the microwave out of the support bracket. Open the door and take out the
glass tray.
Pry off a corner of the plastic panel on the inside of the door with a screwdriver or butter knife. Once it is loose, work the
screwdriver or knife all the way around the glass and remove the panel.
Ask someone to hold the microwave door as you disconnect it from the hinges. Depending on the design of your
microwave door, you may have to remove a set of screws or slide a pin out of the hinge to release the door. Remove and
discard the old door.
Have your assistant hold the replacement door up to the hinges. Attach the door to the hinges by reversing the previous
step. Snap the plastic inner panel into place around the glass. Move the microwave back to its original location. Insert and
tighten the necessary mounting screws if you are working on a built-in microwave. Set the glass tray back inside the
microwave and close the door
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Richard Villarreal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 2,644
