跳转到主内容
Won't turn on even when the MagSafe is plugged in.
Won't turn on even when the MagSafe is plugged in. This is a new MagSafe that had been working. Laptop just stopped working. Is this a hardware issue that could be repaired?
Update (06/08/2017)
It is a ME864LL/A 128GB. I am not aware of any water and or drop damage. I have the back off and do not see any obvious signs. The MagSafe MD565LL/A was from the Online Apple Store and was bought 8/16. This is happened this spring not prior to new MagSafe. There is a thought that it could be the part on the inside of the computer that the MagSafe connects too. I look forward to your reply.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Please give us your exact model as they have been making these sine 2012. Please tell us the history of malfunctions including any spills and impacts. Seems like you bought a new mag-safe, was the same thing going on with the old one. Is the new one Apple branded or a knockoff?
完成的
添加一条评论
2个答案
已选择的解决方案
Here's how to replace the mag-safe board: 交换MacBook Pro 13'' Retina显示器2013末期版本的MagSafe DC-in板
Here's the replacement part: MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board
MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board图片
产品
$14.99
这个答案有帮助吗?
得分 2
添加一条评论
When you plug the MagSafe adapter in, you should see a green light come on the connector. If not, try it on another Macbook. If it works, then probably the MagSafe port on your Mac is probably bad.
这个答案有帮助吗?
得分 0
1条评论:
How do I replace the port on the Mac? I do not have another Mac with the same type of connector to try on another Mac.
完成的
添加一条评论
添加你的答案
Mary Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 5
总计 183
