跳转到主内容
The first generation of the Chevrolet Aveo, identifiable by the internal code T200, the T250 being a facelifted model. This vehicle is also sold as a Pontiac G3, Daewoo Kalos or Pontiac Wave.
22 个问题 查看全部
How to replace the AC condenser?
I went ahead and refilled the freeze on gas on the low pressure end of the vehicle refill pipe. A man told me to relieve the pressure from the high pressure end and continued to fill with freeze on on the low pressure end. The condenser turns on but no cold air comes out.
How do I change the condenser in this vehicle since it does not seem to be working ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@jason5887, Jason, I take it you mean AC compressor. I will post proper charging procedure in a link below. Before changing anything your problem could be a leak in the AC system/bad relay/fuse/plug/wire/switch/etc. and should be checked for this, trouble shooting/repair links below may help solve your AC's issue.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.aa1car.com/library/ac98.htm
https://www.youtube.com/watch?v=pCv7rCdc...
https://www.youtube.com/watch?v=_Peb9o-L...
https://www.youtube.com/watch?v=Pdq8JAlc...
https://www.youtube.com/watch?v=w17DpGCc...
这个答案有帮助吗?
得分 3
1条评论:
Thank you so much I will go though these trouble shooting procedures and hopefully these solve the issue regarding the compressor.
完成的
添加一条评论
添加你的答案
Jason Mendez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 33
总计 2,532
