跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Logic Board Swapping to Access Memory
Hello,
The case is my IPhone 4S has many broken parts, the screen broke, home button not functioning, battery died and charging port is probably broken.
I am trying to recover my data but the phone won't turn on, but I know it's still working because last month I was able to access it briefly (while it's broken like that).
Would it be possible to switch the logic board to access the phone?
And I mean that, can I take the logic board from the broken phone and place it in a new phone (of the same type) and gain my data from it that way?
or should I try replacing all the broken parts?
Any advice is appreciated and thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes, you can swap the board into a different phone and "should" work based on what you are describing. It would be cheaper to perform a repair on that device. You can buy a battery, screen and charging port for pretty cheap.
iPhone4s 电池更换
iPhone 4S 屏幕更换
iPhone 4S Dock Connector Replacement
You could also look around for a whole phone that you could simply out the old board into if you can find one cheaper then that parts are.
Start with a battery if you don't want to buy all the parts to confirm it'll turn on with a new battery.
iPhone 4S 电池图片
指南
iPhone4s 电池更换
难度:
中等
10 - 30 minutes
iPhone 4S 屏幕图片
指南
iPhone 4S 屏幕更换
难度:
困难
1 - 2 hours
iPhone 4S Dock Connector图片
指南
难度:
中等
25 minutes - 1 hour
这个答案有帮助吗?
得分 1
1条评论:
Basing on where I live, it would be easier to buy a phone and replace the inside.
Thank you for the response.
完成的
添加一条评论
添加你的答案
Kylar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 438
