Why won't it turn on?
My nikon won't turn on. I've replaced the battery, fully charged it and still hasn't turned on since I've gotten it. help?!
leaheverhart, If you have already replace the battery and ensured it is fully charged and camera is not powering on, the power button/switch could be faulty, internal bad connection/component on the mother board bad. (1st link is for troubleshooting Nikon Coolpix AW130). If able to return under warranty for repair/replacement/ refund. If not under warranty, the disassembly guide (2nd link)will get you inside to check power button/loose,bad connections/loose, damaged components and enable you to change mother board if deemed necessary. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 37
总计 3,733
