跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
Batter does not charge properly
Power adapter is plugged in. The light on it goes from green to amber, and the lightning bolt shows over the battery indicator. The system report shows the battery is charging. The battery does not charge though. A new battery was installed and the problem is the same.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I disconnected the mag plug, disconnected the battery and disconnected the cable for the mag power adapter inside the laptop. I reconnected the cable for the mag power adapter. I hooked up th power adapter and performed the SMC reset (battery disconnected). I then disconnected the mag power adapter and reconnected the battery. Then I put the mag power adapter back on and started the laptop. Everything seems to be functioning normally.
To recap, the SMC reset only worked after resetting the power adapter plug inside the laptop. I tried it multiple times before.
Thanks for all your help!
完成的
添加一条评论
1个答案
最有帮助的答案
Try reseting the SMC and PRAM first.
please download and run http://www.coconut-flavour.com/coconutba...
Ten tell us your findings.
这个答案有帮助吗?
得分 1
1条评论:
Alright, I performed both of those operations and the problem has not been resolved.
完成的
添加一条评论
添加你的答案
Dbbb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 69
