跳转到主内容
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
50 个问题 查看全部
radio is stuck on am
ok i recently had to replace my battery in my 2008 ford-escape my radio was working fine before i changed the. battery i put the. ew battery in and now my radio is stuck on am and none of the buttons will work i've tried pulling the fuse i've took the unit out and blew it out i even put the same head unit out of another ford escape and it still did the same thing idk what else to do
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Replace face plate it's a control board. Mine got wet from sunroof being left open. I got one from ebay 26 bucks
完成的
添加一条评论
1个答案
已选择的解决方案
@kyle1203, kyle, Try a reset, disconnect the negative battery cable overnight or for at least 8 hours. Hopefully works after this reset, if it does not could mean you have a part failure/internal board faulty. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 2
2条评论:
do you know what part it would. e that would be out
完成的
kyle nichols, Thanks for replying back, I do not know which part could be bad, the radio would have to be disassembled and board/components tested to find fault if need be. May not be cost effective to have radio repaired unless able to repair yourself as good used radio possibly under $100.00 through a search or auto recycler. Good luck with your radio.
完成的
添加一条评论
添加你的答案
kyle nichols 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 39
总计 5,956
