跳转到主内容
User upgradable RAM for 11 Inch MacBook Air
Can I upgrade my 2 GB of RAM on my new (late 2010) 11 inch MacBook Air?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
最有帮助的答案
Hi, According to the included link the ram on your machine can only be upgraded at time of purchase. Sorry.
http://www.everymac.com/systems/apple/ma...
这个答案有帮助吗?
得分 4
添加一条评论
The SSD is secured by a T5 Torx screw. Do NOT try to unscrew it with a T6 or you will thread it. I almost did that since I read somewhere you need a T6 Torx screwdriver and this is INCORRECT. I bought a T5 since it wasn't in my toolkit and that is indeed the correct one. T5. Make note of this.
这个答案有帮助吗?
得分 1
添加一条评论
It looks like they say SSD is not changeable but in reality it is. Maybe the same thing works with ram?
这个答案有帮助吗?
得分 0
添加一条评论
The ram is soldered to the motherboard. When you remove the SSD, which is secured with a t6 torx screw you can clearly see the memory modules. The modules are spread out on the actual logic board rather than a removable memory module.
The 2011 model moves the memory to a new location however it is still soldered directly to the logic board and is not removable.
这个答案有帮助吗?
得分 0
添加一条评论
yes you can easy
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rickdesigndad 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 22
总计 19,478
