User upgradable RAM for 11 Inch MacBook Air
Can I upgrade my 2 GB of RAM on my new (late 2010) 11 inch MacBook Air?
Hi, According to the included link the ram on your machine can only be upgraded at time of purchase. Sorry.
这个答案有帮助吗?
The SSD is secured by a T5 Torx screw. Do NOT try to unscrew it with a T6 or you will thread it. I almost did that since I read somewhere you need a T6 Torx screwdriver and this is INCORRECT. I bought a T5 since it wasn't in my toolkit and that is indeed the correct one. T5. Make note of this.
这个答案有帮助吗?
It looks like they say SSD is not changeable but in reality it is. Maybe the same thing works with ram?
这个答案有帮助吗?
The ram is soldered to the motherboard. When you remove the SSD, which is secured with a t6 torx screw you can clearly see the memory modules. The modules are spread out on the actual logic board rather than a removable memory module.
The 2011 model moves the memory to a new location however it is still soldered directly to the logic board and is not removable.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 19,545
