跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Small Black Square Rubber from Home Button area
When I took off the home button, a small black about 1/8 inch square rubber piece fell out. While gently peeling off the heated cable.
Can anyone tell me where this is supposed to go when I put the home button back on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
It goes over one of the two screw hole right under the home button.
这个答案有帮助吗?
得分 3
1条评论:
Yup, @scottpine is correct. It is the small piece that covers the screw brackets attached to the bottom of the screen. The picture was fuzzy and I should have seen that so good catch.
完成的
添加一条评论
Not too sure what rubber piece you are taking about with the home button. There is not rubber peices on the home button of the 7 or 7 Plus. Can you take a picture of the piece and where it came off and I can tell you what is it and where it goes?
Can you also confirm that you have an iPhone 7 that you are working with?
这个答案有帮助吗?
得分 0
添加一条评论
Here is the picture
这个答案有帮助吗?
得分 0
2条评论:
Did you ever find your answer? Same issue here. Fell out while removing glass (shattered to bits...)
完成的
Never did find where it came from. Whatever it is, it made no difference to the phone. Repaired many other i7 and never came across this rubber piece.
完成的
添加一条评论
The black rubber piece may have come out of another section of the phone. It was probably dislodged earlier and was just waiting to fall out. I just had one fall out of my i7.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe in PA 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,422
