跳转到主内容
Advanced Bluetooth enabled speaker that is compatible with all Bluetooth enabled devices, such as smartphones and music players. Manufactured by The Wand Company, it was released at San Diego Comic-Con in July 2015.
How / where can I get a replacement battery?
My Communicator was left on display on it's unplugged charging base for about 7 or 8 months. The unit would not power up and when I plugged in the charger to charge the unit, the light does not strobe from yellow to red when the Communicator is placed on the charger, but stays strobing blue to green.
Does this mean my battery is damaged and can no longer be charged?
And if so, how or where can I purchase a replacement battery
Thanks....
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
已选择的解决方案
They are actually on eBay. https://www.ebay.com/itm/186054542706
这个答案有帮助吗?
得分 2
1条评论:
@misterm86164 I just added the image of the battery. This is done in case the link should becomes invalid over the next few years. That way people still know what battery they will need for this device. Great job on providing a final answer on a 6 1/2 year old question!
完成的
添加一条评论
I contacted the Wand Company for the same reason. Seems that when the battery flat lines, some defecting charging bases cannot jump start the charge. The Wand Company is sending me a replacement charging base at no cost. Once the battery is charged, I can use my old charging base as a backup. You can also remove the battery and charge it using a cable and correct charger. Once it has some power, you can again use the charging base to fully charge the battery but do not let the battery to completely discharge from that point.
这个答案有帮助吗?
得分 0
3条评论:
Hi, I have a similar issue that the battery wont charge, unfortunately I let it run down without charging it over a long period of time. Do you know if the "jump start" method would work and if so how did you do it?
完成的
Is there an alternate magnetic charger that comes with a stand to charge the communicator without the original stand?
完成的
@paulstanle98763 Did anyone find a charger that would work? I have a battery customer looking for one.
完成的
添加一条评论
Bought mine on Ebay they work great
这个答案有帮助吗?
得分 0
1条评论:
HI, I have a similar issue, can you post the link to the ebay site please so I can have a look and buy one.
Thanks
完成的
添加一条评论
I have them if you need. Been selling them for year. I have contact with The Wand Company.
THE WAND COMPANY Star Trek COMMUNICATOR BATTERY 382527 NEW
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
czero 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 50
总计 1,749
