跳转到主内容
Power button not working
A MacBook A1465 came in today with no power, took it apart tested it all out, found that the power button doesn't work and everything else seem brilliant, my question is can I just replace the keyboard or do I have to replace the full uppercase? TIA
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Here's the part: http://www.ebay.com/itm/Replacement-US-S...
Here's a video on doing it: https://www.youtube.com/watch?v=knI4Bgd7...
Here's how to pull the rivets: https://www.youtube.com/watch?v=djnOVxzb...
I replace the rivets with screws in a kit like this:
https://www.amazon.com/Replacement-US-Ke...
这个答案有帮助吗?
得分 5
5条评论:
awesome mate, thanks, im in the uk and would need it asap
would this work http://www.ebay.co.uk/itm/APPLE-MACBOOK-...
also is it important to replace the rivets with screws, the reason i ask is they take two weeks coming to the uk and i want to get it done asap
完成的
@reecee may know of a supplier in the UK
完成的
@krayzee yes that part is fine. You'll need to order screws too (search on eBay for a1369 keyboard screws). Make sure it's not an issue with the trackpad cable (sometimes this can cause an issue with the power button, instead of the keyboard).
You don't need a backlight, you can reuse the old one if it lights fine, so you should be able to get it for cheaper. As long as it is an A1465 2011-2015 keyboard, it will work fine
完成的
@reecee This comment is what saved my machine. Power button not working, and saw evidence of a liquid on the keyboard. I replaced the keyboard but the problem persisted. Checked the trackpad cable (thanks to your comment) and the connector was severely corroded. Replaced it and now the machine is fixed. Thank you!
完成的
@tburns4 glad it helped you. You thank a answer provider by uo voting the answer
完成的
添加一条评论
添加你的答案
Krayzee 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 4,404
