跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
Why can't I hear sound except through headphones?
I can only hear sound through ear buds or headphones. What can be causing this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It's probably a faulty loud speaker.
I just fixed one last week by replacing it after testing the original one on there with a digital multimeter for continuity (but it was short circuited / open line meaning it would no longer work.)
The problem with just replacing it is that the screen would need to be removed first in order to get the loudspeaker / ringer speaker replaced. This requires very careful care while lifting up the LCD (which is held on by a lot of adhesive) and may end up resulting in a cracked LCD (no display).
If you are willing to take the risk of cracking the LCD and buy the replacement loudspeaker follow this guide to step 27 (You will need to pry out the loudspeaker as it has a adhesive under the speaker to hold it in):
三星 Galaxy S5 主板更换
You can buy the replacement part from here (Used is good as well, but may be slightly quieter than the original one due to being worn out):
[关联产品丢失或禁用: IF236-010-2]
You will also want a replacement screen adhesive as re-using the screen adhesive is probably not a good idea as it gets weakened every time the screen is lifted up (Make sure to clean screen and frame side before install):
http://www.ebay.com.au/itm/Digitizer-LCD...
Guide to install the screen adhesive:
https://www.youtube.com/watch?v=ApgB3ISm...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anita Musser 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 372
