tablet keeps turning self off
RCA Viking Pro tablet keeps turning self off. Battery is fully charged and it still happens. I have only had it for a few months..help!!
这是一个好问题吗?
取消
RCA Android tablet with detachable keyboard, identified by model number RCT6303W87DK.
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店Bill Brown, There is a possibility of a bad installed app. Here is info. from 1st link below. Try booting into Safe Mode, which disables all 3rd party apps. Power on tablet, press and hold Power until the Power Off menu appears. Press and hold Power Off until the Safe Mode prompt appears, then tap OK. if the crashes persist in Safe Mode, then it's more likely hardware-related and you should return the tablet for replacement/refund.
if you tablet keeps of turning off it is probably because you have auto shut down. you can change it in setting. if that dose not work it is probably because the battery in the tablet is not good and needs to be repaired.
评论:
Where do you find Auto shut down in settings
过去的24小时: 25
过去的7天: 121
过去的30天: 575
总计 8,703
it keeps cutting off every time i play a game
由 MARIAH JONES
Where is auto shut down In settings on my RCA Voyager
由 michaelblevins82
@michaelblevins82, it's the Display AutoLock feature that @maker600 is talking about.
由 kmesander
Okay so I have one of those rca laptop tablets. You know the tablet that comes with a keyboard you can put on and take off. Well it keeps shutting off like in the middle of usage. I’ll be watching Netflix and it shuts off restarts and come back on. Why does it keep doing this and how do I fix it
由 Aniya angel
Mine does also :(
由 Kellie
