跳转到主内容
许多尼康单反和点击拍照的傻瓜机的修复指南。
Nikon 5200 charger not working
Hi , I have Nikon 5200 camera.
Recently camera charger fall down and it stopped working. Can it be repaired?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi,
Have you tried checking if the there is any voltage on the terminals with a multi meter. I would suggest checking that first.
完成的
添加一条评论
1个答案
已选择的解决方案
Vinayak Shindagi, The cable or charge port may be damaged. The battery, cable/charger or charge port may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the camera to check the charge port,connections and other components for being loose/burnt/damaged. If not wanting to do the repair yourself have a good local camera repair shop have a look and estimate repair. Good luck.
Nikon D5200 Motherboard Or Camera Back Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vinayak Shindagi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 3,213
