跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
How to replace track pad on MacBook Proearly 2011
I see all kinds of instructions for replacing track pads for every one but mine! Bummer
Macbook Pro 17" Model A1297 Unibody Part #MC725XX/A EARLY 2011 2.2GHz Intel Corei7
I didn't see any instruction videos for ANY Macbook Pro 17"
What to do??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Thanks much for the quick response, I was kinda thinking what you suggested but just wanted a "confirmation" . Thanks again
完成的
No problem! Good luck!
完成的
添加一条评论
1个答案
已选择的解决方案
I would say follow the Teardown of the MacBook 17" from 2009 or follow the removal of the Battery in the Guides there are available. The Touchpad is directly accessible underneath the battery, or at least it should be. If the Touchpad is underneath a black cover, like the keyboard, then you should be able to peel it up safely.
The 17" model shouldn't have changed much from the yearly revisions, but the construction should still be the same: Touchpad underneath the Battery, secured with screws and a ribbon cable. Try that.
MacBook Pro 17" Unibody图片
指南
MacBook Pro 17" Unibody Teardown
难度:
非常容易
MacBook Pro 17" Unibody 电池图片
指南
MacBook Pro 17" Unibody 电池更换
难度:
中等
15 - 45 minutes
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
James Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 222
