跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Transfer to iPhone 6plus
I have an iPhone 5c with a sim and I want to upgrade it to an iPhone 6plus which is not new . The iPhone 6plus has all the apps that I want but It doesn't have a sim . The sim I want to put into it is in the iPhone 5c. Do I have to take it to iplanet or can I do it ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Hello Raageshwari ,
Simply you can do it your self, just connect your iPhone 5C to iTunes and get backup and restore it to iPhone 6+ . sim card is required for the carrier unlock not for the data transfer.
Hope this answer help you to migrate your personal data and apps to iPhone 6+
这个答案有帮助吗?
得分 3
添加一条评论
If you have a computer, simply back up the 5c to iTunes.
Then restore the iTunes backup to the new 6+.
You will then go to Settings --> General --> Reset --> Reset all settings.
这个答案有帮助吗?
得分 1
添加一条评论
To reach it, you need to turn to a professional 3rd-party program - iOS Transfer. With it, you can simply plug your old and new iPhone into the computer at the same time, and select the needed moved data like contacts, text messages, photos, apps, etc. for transferring between iPhone devices selectively or in a batch as you like. And you can also choose to export data from iPhone to computer, iTunes library or other devices without restrictions. Furthermore, this tool can also help you manage your iPhone data like add, delete, edit, etc. contacts info on PC directly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raageshwari 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 96
