跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
My iPhone 5s is getting hot and drains battery fast when using data
My iphone 5s is getting hot and drains battery fast when using data . Can anyone help me fix?
Update (05/19/2017)
Battery is still good. Also tried to replaced it but doesnt fix the problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Do you use it with a PC or Mac?
完成的
I use PC.,,,,
完成的
添加一条评论
4个答案
已选择的解决方案
If the battery is getting hot, it's likely because there is a large current drain occurring (something on your phone is drawing excessive current).
Let your device cool off and then start by disconnecting the screen assembly (follow this guide) and then connecting your phone to an iTunes enabled computer, preferably with a genuine Lightning cable.
Leave it in that condition for 30 minutes to see if the battery still gets hot. If not, then add the screen (LCD & Digitizer) and then the front camera & sensor flex until you isolate the issue. Repair or replace as necessary (or get back to us with more details...make sur update your question or comment on a specific answer so we get notified).
这个答案有帮助吗?
得分 5
2条评论:
Yep. Usually any part on phone that doesn't function properly causes that short circuit issue to the board draining power.
完成的
what could be the problem if it stops heating and draining while on airplane mode?
完成的
添加一条评论
I already fixed them by replacing the the front camera. The other one, I changed the charging port.
Thank you very much.
这个答案有帮助吗?
得分 1
添加一条评论
Have you restarted the phone recently?
这个答案有帮助吗?
得分 0
1条评论:
Yes , also done with hard reset.
完成的
添加一条评论
One more question, is this still good battery or need to be changed? Its iphone 6.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
don 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 7,597
