跳转到主内容
加入维修社区 - 创建账户
中兴手机维修指南
Where is the mute button?
when I receive a call, the caller cannot hear me... as if I have phone on mute. cannot find a mute button
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Does this work with everyone or just that once person? Can they hear you if you use a different phone? Has this always happened or is this something new?
完成的
Just happened the first time. I waited two hrs for someone to call me back with information I needed. They couldn't hear me. I was wondering if the mute button was on. Not sure where to find it.
完成的
Caller can't hear me.where is mute button
完成的
can’t get phone off mute .
完成的
添加一条评论
2个答案
最有帮助的答案
You'll find it on your dial pad click on the icon that has a bunch of squares, microphone with a line across it. I would do a " SIM card pull" as in removing the the back and pulling out the battery and the sim card waith minutes and reinstert and assemble. Prior to this look into Cameron's advice; if its only one person it an issue on the end of that person; if its everybody or an ew occurrence may be a network issue. Then proceed to my advice
这个答案有帮助吗?
得分 3
1条评论:
That took care of my problem! Easy fix! Thanks!
完成的
添加一条评论
People cant hear me on the phone i can hear them please help me
这个答案有帮助吗?
得分 0
1条评论:
Hi,
Here's a link that may be of some help.
Cannot be heard on calls
I realize that this answer is not for your make/model phone but the method is the same, the only difference may be how to get into "safe mode" in your make/model of phone if you want to try and see if it will work this way.
完成的
添加一条评论
添加你的答案
Gary Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 4,492
