跳转到主内容
Repair guides and support for phones manufactured by BLU Products. BLU stands for 'Bold Like Us.'
Cannot be heard on calls
I have a Blu 6.0 Android and nobody can hear me
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
What do I need to do to fix it
完成的
I can't hear voice using ear speaker during call except on loudspeaker
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Jim Cook,
Try using the earphones with the microphone attachment and check if you can be heard OK on a call.
If you can be heard then there is either a problem with the phone's internal microphone or perhaps the voice inlet hole on the bottom edge of the phone is blocked with lint or dust.
To check out whether the inlet hole might be the problem, use a strong light and a magnifying glass to see if it is blocked.
If it is (or even if you can't tell) use a vacuum cleaner, to try and clear the obstruction. Do not use the vacuum cleaner for too long at a time over the hole, use it in short bursts.
DO NOT use a pin or a probe to try and clear the hole. You might damage the microphone which is directly behind the hole.
If you still cannot be heard when using the earphones with the microphone attachment, then there is a problem with the voice transmission circuitry in the phone.
You could try starting the phone in safe mode to check if a downloaded app is the cause of the problem. If you can be heard OK this way then the trick is to find out which downloaded app is the culprit.
If it still doesn't work this way then there is a problem with the systemboard
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jim Cook 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 4,222
